M
M Schunk
Guest
"I have a problem w/ a 1989 Im
"I have a problem w/ a 1989 Imperial Rappalo boat with a volvo penta AQ271c (350).
Originally I had a 715 Holley 4 Barrel which I down sized to a 600 marine carb. When I troll with this boat it fowls plugs and carbons so much that when I attempt to clear the fowling the lake covers w/carbon. I changed plugs (many many times), wires cap and rotor and water/gas serperator (basic tune up) but still fowl after 4 or more hours of trolling. I was wondering if there is anything else I could do. Some people say the coil could be bad, but I was also told by others that it would not run at all ?
others mention ignition modules (I don't even know where this is) could the ignition be an issue. After trolling but will not plane, top speed is reduced to around 10-20mph unless plugs clear which may or may not happen with in 5 miles of travel.
The boat runs good w/fresh plugs, but the rpm tach never goes over 3900, I believe it should be around 4400 to 4600, it has a duo prop and top speed of 37mph, I understand that it's around 26' boat but given my friends boats are close to same footage and weight, they are in the low 40's w/single props. Shouldn't this boat be more like 45mph? Props are in perfect condition.
Any help is appreciated,
89Imperial"
89Imperial"
