Damjan Slapar
Hi all,
i've just put together the combination from the subject line and had it put in the water this weekend.
A few questions, though:
1) Am I fine with the AQ280 outdrive with the AQ225E engine? Asking because the out drive was previously working on the same boat with 6 cyclinder AQ 170 (less power)?
2) I am afraid the AQ280 comes in 1.89 ration variation (I am assuming that because it was, as said, previously running with AQ170 which were supposed to run on 1.89 ration. For 225E, according to Google, 1.61 is best.
a) Can I solve this with a propeller only?
b) What dimension would you recommend? (5.8m boat, 1.400 kg fully loaded).
(Current propeller is completely wrong, needing 5000 RPM for 21 kts - note I just tried it couple of time and did not run engine on this RPM for long time).
c) What should I look at when buyinh new propeller? Only Volvo or other propellers fit as well? (in terms of shaft fitting)
3) The engine starts immediately when cold, but not so good when operationally heated - what should be changed/looked at with this engines?
Thank you very much for your answers/suggestion in advanced.
