realslimshady
"I've fitted a 300 hr 225D
"I've fitted a 300 hr 225D in my boat to replace the old AQ200. It started and ran fine-for about 5 minutes, then died,a and wouldn't fire again-not even a cough. 20 minutes later, fired up instantly, then after 5 minutes or so, the same. I found water in the fuel tank, cleaned that and the fuel filter, and it seemed to be ok.
Monday took her for a seatrial, ran sweetly for over an hour-including 25knots+ across the solent and back, cruised beautifully up through the harbour, then as we passed thru the marina at tickover, died-and not the slightest spark of life on the key. Not a cough or a hiccup-just turned and turned. Splashed some fuel down the carb chokes-started instantly and ran smoothly. I'm thinking fuel pump? Fuel system is unchanged from old engine, which had no problems in this way."
