"Hi to all,
I finally got my
"Hi to all,
I finally got my bellhousing issue taken care of. Motor was reinstalled and reconnected. Upper housing reinstalled etc, etc. I got it started this past saturday using the the waterhose and suction cup deal. My concern is once the engine started I got water blowing through the two outlet tubes on either side at the bottom of the transom plate. Is this correct until the thermostat opens? Once the engine gets up to operating temp and the thermostat opens does this water flow stop at the transom and come out the the exhaust ports above the prop? I'm used to 2 cycle outboards and 2 stroke jetski's. This outdrive thing is all new to me.
Thanks,
Kevin"
I finally got my
"Hi to all,
Thanks,
Kevin"
