"Hi all,
I haven't used m
"Hi all,
I haven't used my AQ170 in a while and did so last week end.
I noticed the engine would hesitate on hard acceleration so I removed the air silencer and noticed that when the accelerator is pumped, the pump jets on all 3 solex 44PAI carbs, hardly pump any fuel at all.
I removed the pump diaphragm of one carb and found that even with the main float bowl full of gas, there is no fuel at all in the pump section.
Is this normal ?
We have gumming issues with the fuel we use so has some little ball valve got stuck or something ?
In the attached photo, the float bowl is full of gas but as you can see no fuel is dripping into the pump area
AQ170 carb
I haven't used m
"Hi all,
Is this normal ?
