Paul McClure
I've got the boat running and had it out at the weekend. At WOT I'm getting around 4250 max RPM - with the Solex PA1's it would pull way past that. The carb is a 38DGES with the following jetting:
Mains 142
Airs 185
Idle 50's
Since the engine was rebuilt, I'm not sure if the issue is that it needs to loosen up a bit (only 12 hours on the meter) or whether I need to go up a main jet size and get more fuel through..or...???? I suppose at the moment it's good for the running in process, since I've got a built in rev limiter ;-)
Mains 142
Airs 185
Idle 50's
