thostorey
Perhaps someone can help me figure this one. An AQ 151C with the electronic ignition conversion and Weber carb conversion.
Not all the time but frequently, when cranking the engine to start, it just cranks and will not catch. Then, when I release the key from the 'crank' position to the ignition ‘on’, position, the engine will frequently start on the last degree or two of engine rotation. I then stopped the engine, turned the ignition key to ‘on’ and jumped the starter solenoid +ve to the ‘key’ terminal and the same thing occurred - it started when I removed the jump. This, I believe, eliminates a problem with the ignition key itself in the cranking circuit as everything else is still in play. I guess my next step is to jump from +ve to the starter wire to bypass the solenoid and see what happens.
It seems that the ignition is being shorted out when the starter is energized via the solenoid but I don’t know where the connection would be. Anyone seen this problem before? Thanks..
