Mike, I swapped out the twin Solexes for a Weber 38 DGES (electric choke) and new intake manifold after reading some positive posts on this forum. The reason for the swap was poor running with the Solexes even after the carbs had been rebuilt, that was later (after the Weber purchase) traced to a missed vacuum leak. Of course with no choke on the Solexes, the Weber is a good upgrade for cold starting.
However it looks like there's been an issue with the carb (which I'm sure is rare - everyone else seems to have had a good experience with the modification) which has resulted in over fuelling. After the bearing went I had the engine rebuilt with the crankshaft reground and new bearings, oil pump, full gasket set and valve stem oil seals etc. The cylinders weren't rebored as they had no visible markings and the piston rings were a good fit.
To date I've swapped out lots of parts:
Ignition leads
Plugs
Fuel pump
Ignition Coil
The fuel in oil issue has been really frustrating - the boat has been in the water since the beginning of June and hasn't managed to move away from the pontoon - and I was actually going to go back to the Solexes - except I seem to have misplaced the fuel line that runs between the two carbs. I have all the linkages and manifold, but am missing that one bit. But since we seem to have verified that all is healthy in the block, I'm going to give the Weber one last chance. If I still have problems after that, then I'll source a replacement fuel line and revert back to the Solexes, or even re-engine the boat, worse case. Given the engine itself is OK then I may just sell it as a good base engine on eBay.
