dearborndeuce
Common prob I realize however everthing is new ( except used head due to corrosion on old one )
All machining done at top rated experienced shop, used head resurfaced & rebuilt w/new guides & seals.
Eng all rebuilt ( had everthing magnafluxed to chk for cracks & all good )
Eng ran perfect for approx 20 hrs and then noticed a hard start ( thinking it might be battery prob )
Chkd everything & found oil level up 1 qt .
Now I know I have a prob as oil can't do that. Water leaked thru to crankcase while sitting .
Exh manifold brand new Barr & no eveidence of water in ports.
Did notice some bubbling in the header tank a few days before & started wondering ?
Removed head & sure enough #1 & #3 show signs of leakage from water jackets into & past cyl seal rings.
Head was surfaced & milled,torqued to factory specs inc the 90 deg pull past the click on the torque wrench.
Anyone with ideas as to why this might have happened ?
Now had the head resurfaced again and have new head gasket.
Before I install I'm looking for expert advice pls so as to prevent same
