laissez_faire
"I recently purchased a boat w
"I recently purchased a boat with a 1986 AQ151A (motor with a heat exchanger). The previous owner said that for each of the past couple years the motor ran slightly hotter, by perhaps a few degrees each year. He believed the thermostat needed to be replaced. Right before I purchased the boat, he removed the original thermostat and went to a local marina to get a replacement. He claims he was told that he didn't need to replace the thermostat and that the motor would run fine without it. I believe this is an 82 degrees Celcius thermostat.
After searching the message board, I've noticed that running with/without the thermostat is a debated topic.
Assuming that the thermostat is in fact the cause of the elevated operating temperature, I'd appreciate comments on running with/without a thermostat."
