AQ151 w290 Outdrive
craigdey
Calling on ALL Volvo Penta Exp
Calling on ALL Volvo Penta Experts!!!
I'm having a huge problem trying to locate replacement parts for the two AQ151 motors. I need one head(at least for now) and two exhaust manifolds. I also need two sea pumps and looking at converting the motors from a point system to an electronic system. The motors have 2 carbs each and both need carb kits(rebuild kits). Can anyone tell me where I can find the parts (After market parts if/where applicable)?
"If your definition of "ex
"If your definition of "expert" is either "someone who has made more mistakes than anyone else" or "someone who has made three consecutive right guesses", then I think I might be able to help.
Carb rebuild kits:
http://www.marineengine.com/parts/part_details.php?pnum=SIE18-7000&returntopage= 80240775.htm
Exhaust manifolds:
http://www.marineengine.com/parts/part_details.php?pnum=SIE18-1930-1&returntopag e=80240786.htm
Pertronix electronic ignition kits: go to your friendly neighbourhood autoparts store and ask for Pertronix kit #2842. You can also search this forum, as this item has been debated countless times. Here is an example:
http://www.marineengine.com/discus/messages/12487/84653.shtml
Raw water pumps: do you need the whole pump or just the rebuild kits? If you need the kits, look at this:
http://www.marineengine.com/parts/part_details.php?pnum=SIE18-3205&returntopage= 80240779.htm
and this
http://www.marineengine.com/parts/part_details.php?pnum=SIE18-3075&returntopage= 80240778.htm
If you need the pump, see this:
http://www.volvopentastore.com/SEA_WATER_PUMP_855578/dm/store_id.366--session_id .408682715--cart_id.405026455--category_id.332608--list_time.1198872652--view_id .321156
and this (part 855578)
http://www.depcopump.com/catalog107/103.pdf
Regarding heads, many automotive heads will fit, but you will have to use your current marine camshafts. I don't know where you are located, but the guys in the following link may be able to help. Give them a call (preferably at Cobble Hill) and tell them what you need, they have a 1-800 number.
http://www.chapmanmotors.ca/volvoparts.html
http://www.chapmanmotors.ca/contactus.html"
"[b]"If your definition of
""If your definition of "expert" is either "someone who has made more mistakes than anyone else" or "someone who has made three consecutive right guesses", then I think I might be able to help."
Ayuh,.......
I Love your response El Pescador.........
I hope you don't Mind,.......
I might have to use that line someday........."
"No problem, Bondo. I believe
"No problem, Bondo. I believe that the above definitons apply to many of us anyway.
Happy new year to all the forum folks.
