T
Tom Struthers
Guest
Can anyone advise me on the
Can anyone advise me on the design and function of the Inlet Manifold Heating system on my AQ 151 B.
The inlet manifold has what appears to be heating jackets below where each of the carburettors connect.
There are brass drain plugs at the bottom of each of the jackets which are interconnected through the manifold casting.
The manifold has coolant connections just below the number 1 and 4 inlet ports to the cylinder head however the cylinder head only has a matching connection at the number 4 port. The coolant connection at the number 1 port on the cylinder head is a blind hole.
This arrangement does not allow a circulation of the coolant between the cylinder head and the inlet manifold.
Should the coolant connection at the number 1 inlet port on the cylinder head be drilled through into the coolant gallery to allow circulation?
