"I have just purchased to seal
"I have just purchased to seals part number 831892-5.There are 2 seals that go between the Plastic strainer and the and the heat exchanger.When I purchased the second hand strainer body and strainer insert. I removed the old strainer and found that there was no gasket(part number 831892-5)between the strainer body and heat exchanger body, where the manal and exploded view shows.When I pulled the old one off the heat exchanger I found that there was no rubber gaskets(part number 831892-5).I am sure that the strainer plastic body that I purchased was of a AQ125 and it said that it also fits a AQ140.AQ145.When putting it together it seems that there is to much gap between the plastic stainer and the heat exchanger base.there is also a nylon ring that fits over the heat exchanger base so the plastic strainer bodt can fit onto.At the top of the heat exchanger of the ther is a rubber seal that sit inside the base of the haet excahnger and it seems that the nylon seal fits on top of this to put pressure on the seal eliminating leaks.My question is do the seals I purchased have to be utilised(because they were'nt any before)or is this just for the AQ125 stainer.It just seems to me that if I install these 2 seals that the strainer will be siting a bit high and the seperation inside the stainer may let water into the wrong chambers somehow.Anybody help on this situation will be appreciated."
