87point2psi
Hello
Ive been picking away at my aq145 since i got it, cleaning exhaust manifolds, doing some painting ,rethreaded the ridiculous greaser in the FWC and replaced it with grease fitting on 18"hose etc, yesterday I removed the points and installed a pertronix electronic ignitor. I must say right off that this made a huge difference in the start warm up cycle, before, I had to pump the throttle to keep it running until it warmed up,were talking 5 or so minutes and 6 or seven starts, then it would run fine on its own...now it starts right away and although i still have to give it a little extra gas at first, it runs on its own at idle after about 15 seconds- 1 start. Anyone that is thinking of doing this upgrade, I say do it, best 100 bucks I have spent so far! It should be noted, that first start after install, it would not start- I had to advance the timing a considerable amount before it would fire up. Leading to my question: I have put a timing light on it and set the timing at 8 deg base, Since Ive been reading this forum so much, it has been driven into my head the importance of timing advance (Ricardo) and I now need to check it at 4200 rpm- Do I do this on the water under load? 4200 seems a little high speed with no load to me.How do you guys do it? I dont have any help so I would have to set the throttle and go back to the engine and put the light on it, then back up to the throttle to decrease rpm.
Also what do you guys think of this.....I could have sworn that the engine called for 10w-30 in the specs, but I later discovered that it calls for 10w-40, so I in fact put the wrong oil in it, its full synthetic so kinda spendy, so I was thinking of grabbing some lucas oil additive and throwing it in there to stiffen it up a bit...any thought on this or should I change it to something thicker?
One more question: how many pumps of grease into the flywheel cover? Any way of telling if your "there" or not or is it just a good guess?
thanks all.
thanks all.
