Follow up:
Finally got around to getting this done today, had to wait for o-rings etc to come in.
I would like to say thank you Ricardo for the advice on how to go about getting this done!
You are very welcome!
Pulled the tranny, found water in the bellows and 2 rusty u-joints, a hole in the lower forward part of the bellows that I hadnt noticed until I removed the bellows. the U-joints were still functional but the forward one was quite stiff and upon removal found to be bone dry of grease. I changed out both u-joints without removing the yoke from the transmission.after that was done, I moved on to the PDS bearing, once i got the rear seal removed, I could see that everything was in good shape considering the hole in the bellows, there was no water forward of the seal and the bearing looked to be in good condition.....Of course I swapped out the bearing anyways since I had come that far and had a brand newie in my pocket
You'll never know how wise that decision was!
...things went pretty much as read about here, couldnt get the shaft out after snap rings were removed, so a good pair of vice grips with a chain through the jaws ala homemade slide hammer got it out in a few hits, I know this is a nightmare on some boats if its really corroded in there, im lucky mine came out without too much hassle. Everything went back together as advertised, new o-rings all around.Took boat out for a run and worked great.
Excellent!
Did the timing belt today as well, and ill replace the exhaust manifold tomorrow since the heat exchanger is already off.
A couple things to be noted though.. the rear seal was facing forward on both my boat, and the spare FWC i had that I practiced on before I tackled the one in the boat. Does Volvo install them this way and turning the seal around is a modification?
No and No!
The factory would have installed this seal as I described.
Just wondering because both the ones I did were in spring forward.I installed mine with the spring facing rearward so that the grease can push through if it has to.
Correct!
Also....How the hell do you get that helmut pin out if it has 2 bolts but NO jack screw holes??? I ended up removing the steering helmut and it was a pain in the ass to get the bolts back in! Im sure this is not the last time im going to be in there so I would love to know the secret to this!!
If the jack screw threads are not there, it can be a PITA. You can replace the helmet pin with the style that has the two jack threads.
Make sure that the two cap screws are of the correct length. Too long, and they will break through the aluminum clamping collar allowing water intrusion.
