"what sort of problems do you
"what sort of problems do you encouner when the exhast manifold is suspect of corrosion.i have repaired the no.4 port with a filler (lead) seems to work very,very good after i had tried a number of aluminium filler products.i suspect that there is water going into the no 4 port because i started it up on one of our outings and heard a noise like the valve had had a bit if rust in it and sounded like a valve stem dry and rubbing in the head.this only lasted for about 1 min (max) and was quiet after that.trying to get the most out of this fishing period before i remove the exhaust manifold to see how corroded it is.i suspect the manifold is not in a good condition and trying to avoid big codts.will running it in this condition have bad results for a the next month or so,or will it be the same.i donrt have any problems with the motor at the moment it run very good.i will inspect the manifold when i take it of but from experience from youall i would like an opion if these manifolds are successfully welded after corrosion sets in or do you think that they are a complete waste of time rebuilding.i also will have to face the situation abount the head in regards to the ports 3/4 to see if they are servisable or not.comments please"
