"OK..........first time here b
"OK..........first time here but I'm near the end of my rope. I have a 1978 Volvo AQ140A with a 280 leg. It would not start at the beginning of the year so I replaced the points with a Petronix electronic ignition c/w flame thrower coil, new cap, rotor and ignition wire set. I later found out the timing belt jumped so I replaced it and a new pulley tensioner (this was the original problem as it was rusted tight). I also replaced the water circulation pump and raw water pump with a rebuild kit. Many trips to Lordco and Anchorage Marine !!! It turned over and ran a little rough so I timed it to 6 deg BTC and it worked great (in my driveway). I noticed the battery was a little low so I put it on charge overnight. I took it out to the lake today for a trial - started fine ran for five minutes and died. After turning it over several times I noticed the battery was running low very quickly (low enough not to lift the leg). The battery is fairly new and I have not checked my alternator yet. Someone told me to install the Pertronix Ingitor wire to + side of the coil - so i did but I noticed Pertronix suggests installing the Red + wire to the ignition side of the ballast resistor. By bypassing the ballast resistor have I somehow created a short and drained the battery or fried the electronic ignition ? ....any suggestion welcome please !"
