Bob, this engine is very simple and easy to remove........... and in particular if it's cantilever hung.I striped the oil pan bolt threads. Leaks like a well
Ok Ill need to pull the motor No big deal.
Q is can i leave the bellhousing on OD? I have lot of forward room
Ill remove the upper gear on OD so the input shaft will be free to spin.
Bob, I've done the same on my twin SBC's. I used a 1/2" pipe coupler split in half to gain the same taper on each piece.Got the pan off will be welding a pipe fitting to the pan to a new oil drain system.
When it comes to install is there anything I should know about, or is it strait forward.
Referring to Bellhousing alinement?
Ill do a dry run first bellbousing only no motor see how that works out. Then remove BH put BH on motor and do a final.
Other than that I think Im OK
I used 1/2" SAE oil hose, threaded SAE hose fitting into oil pan TPT.
I use the Tempo Oil Boy extractor.... and it works great.
Bob, you are refering to the Flywheel Cover, correct? (bell housing is an automotive term).
If so, yes, there will be an initial alignment via triangulation between the 6 flat areas (3 on transom shield, and 3 at F/C)
There will also be a concern for Port/Stbd rotation, in that the "torque" trunion must align, as well as the exhaust manifold must align with the down tube.
I'd suggest that you re-assemble the engine with the F/C attached, and install as a unit.
Leave the clamping collar loose until all aligns.
Replace at minimum the inboard rubber cushion.... they seldom go second time around.
This one provides the water seal.
