"Well, I hope that you are kid
"Well, I hope that you are kidding about the tree and the jeep!
Are you trying to remove the transmission only at this time? I hope so.
There is no need to remove the entire drive for this work. Not unless you have other work such as Pivot Tube bearing/seals, etc.
And even at that, you still want to remove the transmission only at first.
(Go back together in this same sequence...... Intermediate/main fork.... transmission last)
There will be a total of four fasteners...... two nuts/two bolts secured UP into the transmission housing.
If you remove these four, the only thing holding this in place will be some type of sealant that some knuckle-head put on there last time it was assembled.
Heat can be your friend on this...... a heat gun.... a small propane torch, etc. NO Oxi-Acetylene unless you know how to richen the fuel to oxi mixture, and even then, you must be careful to not over-heat this.
It will come off.
Watch for and inventory the shims between the trans and Intermediate housing..... they are critical to get back in place as they were.
To access the U joint AFT yoke "cap screw", the bearing box needs to be removed. The four clamping collar bolts will be your next challenge.
Again..... heat on the main gear case where the female threads are.
I've gotten to where I rarely even attempt to disassemble one of these without the use of heat!
You are another member who is just north of me in Washington State. I am in Portland, OR.
While I don't want to use this site for soliciting work (and I don't need the work) I have people ship these to me for repair if that interests you.
