I am finding some time to work on the AQ140/280 that I have posted questions about earlier this summer. I pulled the PDS and the bearing. There is another small roller bearing in the flywheel cover cavity past the forward seal and forward of the B/W splines. This bearing appears to be in good condition but there is not much grease up there. Nor was there enough grease in the rear bearing cavity and it appears that someone fairly recently installed a shiny new SKF bearing without sufficient lubrication and with the seal facing the wrong direction. I might have already dodged a bullet here and am replacing the rear bearing just in case. I have also tapped a grease zirk into the flywheel cover to replace the capped port so that should prevent future lubrication problems.
How is this forward bearing serviced and lubricated? Is there anything I should know about this bearing before re-installing the PDS with the new bearing and aft seal? The forward seal appears to be in good condition, should I replace it too?
I have the Volvo service manuals but I can't find any useful info about this bearing.
Thanks for your help.
