AQ131C
david_f
"Engine ran on start up for ap
"Engine ran on start up for approx 60 secs at 2000 rpm, throttled back & engine cut out. Changed points & cleaned carb. Fuel not getting sucked through manifold & can be seen pooling in manifold, checked compresion when cold all cylinders just showing 50 psi. Could timing belt have jumped teeth or is this more serious."
"Found the problem, timing bel
"Found the problem, timing belt had sliped 2 notches, now got 160 psi when engine cold on all cylinders"
"Have you found why did it sli
"Have you found why did it slip? You may want to look at the condition of the timing belt, the timing gears, and the tensioner, or it may happen again."
"Thanks for that, cleaned up g
"Thanks for that, cleaned up gears with wire brush, tensioner was in poor condition and will change the belt. got the boat cheap so expecting some problems but am happy now with the compresion reading. Could you tell me if the Petronix ignition kit is the way to go or would you recommend another make, if so what is the model number. Regards Davie"
"I know that Pertronix (ig
"I know that Pertronix (ignitor #2842 is the one for your distributor) is reliable (I use it myself), not sure about Hot Spark. Opinions seem divided about the latter, but it is definitely cheaper than Pertronix."
"thanks for that El, will look
"thanks for that El, will look for a supplier in the U.K. if you use the Petronix thats good enough for me"
"Pertronix is superior.......N
"Pertronix is superior.......No problems. Try it out. Cheap and easy to install. Totally eliminates ignition probs for, as I now have it, two years!!!!"
