AQ131C Carb
david_f
"Engine running fine but not t
"Engine running fine but not totaly happy with Solex carb, any recommendations for aftermarket replacement would be appreciated."
Search the Volvo Penta forum f
Search the Volvo Penta forum for "Weber". Some people have reported positive results by going from Solex to Weber.
"aquired twin solex carbs comp
"aquired twin solex carbs complete with manifold just needs 1 spark arrestor, 2 diaphrams & gasket, everything else looks in good condition. Has anybody tried this setup & is it worth trying"
"I haven't tried it, but y
"I haven't tried it, but you may want to consider upgrading from an A cam to a V cam if by installing twon carbs you are looking for some extra power. Also, if you install twin carbs, make sure you synchronize them properly."
"thanks for that El, don't
"thanks for that El, don't think I will bother if I have to change the cam. Happy with the top end-getting 33 knots on a 19' sports craft it just seems sluggish out of the hole but used to having 2 stroke Mercury outboards this is first inboard motor."
"You don't have to change
"You don't have to change the cam, I am just mentioning that VP 4 cylinder engines with dual carb usually have a V or a K cam. The A cam comes installed on engines with single carb, but that does not mean it won't work with a two carb arrangement (however, I haven't tried it)."
"Hey thanks for that, well if
"Hey thanks for that, well if I am not going to do any harm I will probably rebuild the carbs & give them a go- might give better accelaration."
