Hey everyone, I just bought a boat for the first time ever it is a barette open bow 19 ft it has a penta Aq131a 275 Volvo outdrive I have a few problems when I took it out for first time first thing steering was very easy out in nuetruel but once in gear pulls completely left and steering gets very hard to turn ???
On the 275 drive, the exhaust outlet housing serves as the trim fin/torque tab. It is rather small, and does not do an effective job at it, unlike the 280 etc.
If the boat pulls to the Port side, you'll need to adjust the trim fin/torque tab to Port.
Loosen the center bolt and make an adjustment.
This will help remove what we call prop wash steer torque.
You will not be able to correct it for all speeds, but it will help.
Keep adjusting it until you get it correct for the speed that you cruise at.
Also when I went to take it out of the water I could not get my tilt up even one person in water lifting while one pushes tilt up.
I had to take a but off hit the bolt out that runs horizontally through the out drive at the bottom
That would be the "set pin", and it should be installed in the center position.
As you operate the Lift Out unit, the vice rod will extend.
As it extends, the vice rod pressure plate will contact the push rod thrust sleeve.
The push rod will depress the latch unit and it should release for Lift Out.
If not, you'll need to go through the entire system and find out what is wrong.
it freed then tilt took it right up works up and down until it fully goes all the way down then it latches around that bolt ????
Correct..... if all is working, as the drive is lowered, the latch hooks will grab and hold onto the set pin.
The system is actually a "break-a-way" feature in the event of an impact.
