smokediver
"Hello all,
I've got a
"Hello all,
I've got a 19' Bayliner Capri with an AQ131A/275 pushing it through the water. I lost electrical power the other day after changing out the ignition relay. Turns out it was a blown fuse under the dash. The engine still won't start, but at least it the solenoid will click now when I turn the key.
The fuse I pulled out was a 5 Amp. I didn't have another 5A fuse handy so I put in a 20A until I can get to the store. I turned the key on and Voila, the instrument panel came to life. I turned the key to start and...nothing. The 20A fuse blew. So, I put in a 30A fuse and it seems to be stable. FYI - The ignition relay is a 30A relay. I'm not sure if that matters in relation to the fuse.
This particular circuit powers the tilt motor, the instrument panel and its' lights, and sends power to the starter solenoid. Does it seem odd that all of this was working previously on a 5A fuse? Seems rather low in seeing that it was the fuse for all of these high amp devices.
I was looking at the wiring diagram in my Clymer book, and the wiring in the boat matches the book, there are no apparent shorts, and everything seems to be in order now.
My main question is, does anyone know what the proper fuse amperage is for this particular circuit?
Also, can anyone make a guess as to why the starter won't engage? Even when hooked up to a 75A booster. The starter and solenoid are new, the batteries appear to be in satisfactory condition. I had them load tested a few weeks ago and they both passed.
Thanks,
Chris"
I've got a
"Hello all,
Thanks,
Chris"
