"Working on a AQ 131a. Had no
"Working on a AQ 131a. Had no power and would not idle except when warm. Rebuilt the card and adjusted the timing. It now idles perfect with timing at 6 deg. At high end under a load it still is not hitting max rpm’s. At full throttle we are getting 3100-3200 rpms, lower than it should be.
The gas is a bit old but has been stabilized and the idle is just to smooth for it to be just the gas. The throttle is going to full extension but the rpm are just not there. It is very responsive but just does not have as much power as it should. Plug gap is .028 and the advance is working great. Could it be the dwell and what should it be adjusted too?"
