Hello All:
I have a 19' Bayliner Capri with a Volvo Penta AQ131A. It ran great last season then we winterized it in November (we have long seasons) we took it out in Feburary and put in the water. Fresh gas and it fired on the first crank as always. went to back it off the trailer and it sputtered and died. we have been fighting with it ever since. we hav changed the following. Timing belt ( broke 2 teeth), Fuel pump (had less than a pound of pressure), Accelerator pump, (fuel sputtered under throttle throw), checked timing under idle (was spot on) 6-7 degrees at 4000 rpm without load. I can't understand what could have changed so quickly that would cause this. We had the outdrive checked and it got high marks except for a slight play on the prop shaft that the shop said was well within reason and to fix it would require a full pull down bit the outdrive was not binding in any way. we had the prop tuned at winterizing but the shop we took it to has triple checked that aspect.
any help would be appriciated.
