My aq131a runs well at idle and cruise speed.when I try to open her up she overheats..? when i back off of the gas and slow it down just a little she cools back down and is fine....the dealer said to check water intake rubber hose from drive to engine for air leaks..it looks good..next he said to check timing...its set as recommended -6 degrees btdc @850 rpm....new impeller, looks good and is moving the lake water through the cooling system pretty good..when I put on the muffs in the driveway the water from the exhaust will gush in spurts rather than a steady flow..? I checked the manifolds and there clear. I don't know what the boot is called but, I have a tiny pin hole that I plugged on the large rigid booty on the out drive, this did not seem to help it any. Could something clogged up in the out drive? how could I check it? Info on my overheating problem I would be thankful.. Rich GREAT FORUM LOTS OF INFO
