B
brianb
Guest
dealer said my overheating pr
dealer said my overheating problem could be a timing issue because my engine only overheats when at higher rpm's so i put the timing light on plug wire closest to the front of boat thinking this is #1 cylinder.at what rpm should i set timing? and should timing be set to -6 degrees btdc..?any info would be greatly appriciated..thanks.
