AQ131A Engine Swap
liliner
"Hi, I'm new to this forum
"Hi, I'm new to this forum and have been reading various posts regarding using automotive engine assemblies and swapping the marine externals and cams. I have a 1986 AQ131A and have seen posts stating that an automotive B23 engine up to 1984 may be used as a replacement. My question is will a later B230F or B230FD work also (as long as it is the distributor in block version)?"
"Carl, according to the info I
"Carl, according to the info I have, the AQ131A is a B230 (not a B23) block, so a B230F (non-turbo) engine should work. That engine is installed on several 85-92 volvo car models."
"Hey thanks for the quick repl
"Hey thanks for the quick reply and great info. One more thing. Although I know the marine crank is forged as opposed to the automotive version, are the rods and pistons the same for an AQ131A and a B230? If not, is there a serious down side to simply rebuilding the B230 with automotive parts (except gaskets and core plugs, and camshaft of course)."
