There is a Marine version electronic ignition distributor for this engine. I just did a search, and I cannot find it, but I have seen it before. It was very expensive.
The only other option, is to convert the Bosch OEM ignition distributor to electronic triggerign via the Pertronix (or similar) kit.
These kits are Hall Effect, and a lousy attempt at that, IMOO.
I'd normally try to steer any of us away from this, but unfortunately, this is the only means for electronic triggering without paying the high $$$ for this unit that I can't seem to find right now.
This old distributor no doubt shows some signs of wear by now. Possibly shaft bushing wear, possibly wear to the flyweight system, or perhaps compromised flyweight return springs.
Suggestion:
Take your Bosch unit in to a shop who owns and routinely operates an old Sun or Allen distributor machine.
They can re-bush the upper and lower areas, and they can re-adjust the flyweight system as to bring it back into OEM specs.
You'll need to provide the specs for them. These can be found in your OEM manual.
They also like to have the contacts points in them during the calibration.
The Pertronix kit can be installed afterwards.
Second suggestion:
The pertronix kit will offer a shim that is to adjust the height of the sensor unit. Often the height does not match up correctly with the magnetic unit. An adjustment here will ensure that the two talk to each other correctly.
If you can, talk the shop into doing this, they may have a better means of testing it.
Now you can re-install it, set BASE advance, warm the engine up, and check your total advance.
I'd not set BASE advance only and walk away.
Always check the progressive and TA.
