AQ131A running fine in the San Juans, then began suddenly to choke up. Had to pump the throttle to keep it running and get home. Now at home, it starts but will not hold idlle or any rpms without violently pumping the throttle. Can rev it up to 3000 rpm but will not hold at any setting.
Here's what I've done so far. The motor was timed by a volvo tech two weeks ago and has been running fine. This motor has a rebuilt distributor, new plugs, points, wires, coil, dist cap etc. I checked the points and rotor and cap again, no problem. Pulled the fuel filter and found watery fuel so replaced the filter. Pulled that filter and it has clean fuel now. Also ran my kicker for awhile as it gets fuel from the same tank. No problem there. Checked the fuel tank vent and it is clear. Just to be double sure I'm siphoning the tank in order to replace it with clean gas and eliminate that problem. However, the fuel I'm getting out looks clean and doesn't separate when in a glass jar.
My question is what to do next? Should I just plan on rebuilding the carb or are there other checks I could make before I do that?
I'm feeling like it's a fuel delivery issue because when it does run, it doesn't stumble or miss. In fact, yesterday it would idle at 800 rpm's with no problem. Advance the throttle and she died.
Any thoughts?
Any thoughts?
