"last summer, right after I ha
"last summer, right after I had my carb rebuilt, my engine blew a connecting rod through the engine block. before parting out the boat, I found and purchased a used replacement aq131a }}motor that started and ran with some backfiring.
All of the marinengine.com contributers were great!!I replaced the spark plugs, installed a Pertronix electronic ignition and and changed the oil, I installed the engine last fall, drained the engine at the fresh water pump and added pereservatives to the gas in the gas tank. This spring, the engine started after multiple tries and after priming the fuel pump with gas but it backfires frequently and often stalls after backfiring. I let the engine idle for about 30 minutes. The backfiring is less, but still too frequent. If it does't stall, the backfiring seems less when I open up the throttle (in neutral).
Any help would be greatly appreciated
One of the ignition wire boots seems loser at the spark plug end than the other three.Could this cause the backfiring?
Could it be bad gas?
Shoud I just replace the old carb with the one that I had rebuit last year from the blown engine?
