Welcome new member.
1. The text editor on this site does not work very good. I have to type slow and check every character.
So your post seems to read wrong. Can you edit it, what is your boats problem?
I can only get about 3200 rpm with my aq131a 275 out drive 15x19 prop
Are you setting the points with a dwell meter? Set the points at around 60-62 degrees using a dwell meter and then adjust the timing to 6 degrees BTDC. Then check the progressive timing advance the timing should advance steadly with RPM and should stop around 32-36 degrees at 4200. Is this a older bayliner?
I have one carb.i checked the carb it's good . There is an aftermarket hydrofoil on it. I noticed the exhaust is pointing straight back. Could that be a problemOK, so you just bought the boat.
Check easy things first.
With engine NOT running, set full throttle and see if carburetor goes full open.
Do you have two carbs or one?
Does the back of the boat have trim tabs? Maybe you have a boat problem not a motor problem.
Does about 25mph . Engine sounds good
