"AQ131a Overheating
Hi ,
I
"AQ131a Overheating
Hi ,
I know that overheating problem was on forum 1000000 times
I did read most of posts but couldnt find answer for my problem.
I have got two Aq131a on boat.
Portside engine is overheating when is on load at 3000-3500 rpm .
When boat is not moving I can rev 4500, keep it for long time
and engine will not overheat.
Starboard engine works properly.
What I did:
1) water passage between sterndrive and raw water pump is clear.
2) I changed water hose connector on sterndrive for new one.
3) impeller on raw water pump looks very good.
4) I checked heat exchanger , exhaust manifold, there is no blockage
5) Fresh water pump looks good.
6) Installed new thermostat.
Is anything else what I can check? where can to be problem?
Sebski"
Hi ,
I
"AQ131a Overheating
Hi ,
What I did:
Sebski"
