Raw water cooled or with heat exchanger?
There is a metering port in the exhaust elbow where the "excess" water is allowed to flow into the exhaust stream. Check there...
Also... check in the T'stat housing. Are you sure that the cam gear is driving the impeller? Did you insert the key in the impeller when you replaced it? Is the pump drive shaft indexed (and in good shape) to the cam gear?
No strainer, but the bundle of small tubes that constitutes the cooler, makes an effective block to larger pieces of "stuff"... Many years ago, I had to install a sea water strainer on the input of the raw water pump to keep junk out of the oil cooler's water circuit. Ever since, I've installed seawater strainers of one type or another on all my boats (except my Merc drive Bertram 25... a moment of silence for a great boat gone before its time...) . My current boat has an external wedge shaped strainer mounted externally on the hull... 14 seasons and no crap in engine raw water circuit issues. This arrangement also improves impeller life since running it aground briefly on an unmarked bar ( I boat on Barnegat Bay... anyone who claims to not bump the bottom on occasion either lies or never leaves the slip) does not result in sand and crap being sucked into the impeller and damaging it.
Thanks. Will removing the water input side end cap on the cooler upset the seal on the water output side? Or will that end cap stay in place undisturbed? I'm just trying to get an idea of what I may face when I remove the input side's cap.
I and a similar problem to yours after replacing the impellor i found that very little water coming out of the exhaust port so i removed the elbow on the end of the outlet manifold and found it be restricted badly with rust so i cleaned it out with a flexible hacksaw blade pulling it backwards and forwards over a couple of hours and this solved the problem
This was the same motor as yours
Just for the record, the pressure from the garden hose was purposely set pretty low, but either way water is still being pushed though the system. I'm next going to detach the output side of the pump and attach a hose that I will run into the bilge (with drain plug out of course), then re-run the "water from a bucket" test to see if the pump will suck up water and discharge it out the fore mentioned hose and into the bilge.
I had the same issue after changing the impeller this spring. When I removed the pump the intake side drained all the water out as well as the the outflow side. I could not get the pump to prime. I ended up filling all the lines with water while I had muffs hooked up to the outdrive and the pump was able to prime.
How did you fill the lines with water? There is no place to inject water into the cooling system on an AQ130C unless you remove the line from either the input our output side of the water pump.
