AQ130C Starter
holeinwater
"I found a starter that is lis
"I found a starter that is listed to fit the B18 B20 and models 122, 544 and the 140. Will this starter fit the AQ130C? They look identical."
"I would think so. The old V/
"I would think so. The old V/P part number for the starter is 870977 (new part# 834339) and I located references to it when I googled "volvo b20 starter". But before you buy, I would suggest waiting for someone more qualified than I to chime in."
"If this is an automotive star
"If this is an automotive starter you are looking at, I believe marine starters are different from automotive, even though the fit may be the same. Marine starters are built to be anti-spark. Maybe someone with more knowledge will clarify this.
Jon"
"Maybe more corrosion resistan
"Maybe more corrosion resistant, but cost wise? HMMMMMMMMMMMMM............ I have an auto starter in my freshwater boat that has lasted since 1985. Still fires right up. No problem.
I don't know about you salt-water guys, but in fresh water, I would go automotive. IT IS CHEAPER!!!!!!"
