"I have 2 AQ130c,s one of whic
"I have 2 AQ130c,s one of which is over heating when i go over about 2,800 rpm. This problem seems to getting worse as it only used to over heat above 4,000 before. I have disconected the the sea water filter and given it a good clean and have blown down the pipe that goes to the leg to see if it is blocked but its all clear. This weekend i changed the impeller just incase something was wrong there but having tested it there is no difference it still overheats. Interestingly it does,nt overheat if I run at anything under the 2,800 its just when I go higher and if i go higher then lower the rpm back below 2,800 it does come back down but very slowly. Any ideas what should be my next step ? O and I have checked the drive belt to ensure the tension is correct in case it was slipping causing the impeller not work!"
