"My 130c will not run unless I
"My 130c will not run unless I pull the coil wire out of the distributer cap about a quater inch.only then it will fire and run.I put in a new pertronix kit,wires roter and cap,also new flame thrower coil.When the coil wire is seated inside the cap the engine only turns over it will not start,but when you pull the wire out you can see spark and it starts and runs????If you put the wire in while its running it stalls,I could controll wether the engine runs or not by moveing this wire in or out of the cap.Can anyone tell me why this is happening or how to fix this.....Thanks Walt."
