am_dew
Advanced Contributor
As part of my spring maintenance after the boat being not used since early October 2021, I was going to change the oil and filter. However, the oil filter is not coming off. I have tried a standard oil filter strap type wrench as well as two different flute cap style wrenches that you use with a socket ratchet. In desperation, I drilled a hole though the filter and then stuck a very large screwdriver through the filter to try and get better leverage, but the filter did not budge with the screwdriver shaft tearing through the filter body as I applied leverage.
Coincidentally, the oil I drained out of the engine was milky. Although I have no way of proving this, I suspect this is due to excess water pressure from a garden hose being applied to the intake side of the engine mounted water pump by a mechanic who I had look at and fix an issue with my alternator (the boat was trailered at the time). The engine had not been run since he ran it except just yesterday when I ran the engine to warm up the oil before draining it. Before I ran the engine, I checked the oil at the dipstick and it did appear to be a little lighter in color than it normally is, but it's also hard to tell the condition of the oil from the dipstick when the engine has been idle for 5 months. I am almost 100% certain that the oil was fine when I took the boat to him as I always check the oil after every outing.
is it possible that the oil filter's threads have rusted onto the threaded spindle on the engine block? Any suggestions how to go about removing the filter given that the methods I have already tried did not work?
Thanks!
Thanks!
