Alton Toth
So I'm entirely new to this forum (in case you couldn't tell for some reason). I came into a 16' Double Eagle boat with trailer for a song and a dance (well, just the dance, I can't sing worth a darn). It had been sold locally in 83, and spent it's whole life here (Sunshine Coast, BC), but the main reason I got it? No engine! I have the outdrive, and the hull is solid and intact, just no engine for it.
I did some research with Double Eagle, and found out what it had in it when it was new. I spent a few months trying to find a matching or similar engine (AQ125A) that I could mate up to the already installed transom shield and the 270 leg I have on hand. I managed to come across an entire engine and outdrive that had only ever been used in fresh water that I managed to pick up for $500 through eBay (the guy had also listed it on CL for $1700, but I wound up being the only bid). A 17 hour trip to Oregon and back to pick it up (along with a ton of boat hardware he threw in to be rid of it) and I now have a complete power plant for the boat that isn't too dissimilar to what the boat shipped with originally.
I've been reading a TON of forum posts, and trying to find what manuals I can, etc. I tried to remove the outdrive from the transom shield (the boat had been sawzalled away from the shield and engine, so was all one unit), but unfortunately could not drive out one of the pivot pins, and snapped the head off the keeper screw for the OTHER pivot pin. Luckily I have a whole other shield and outdrive to take parts from. I was able to undo the bolts in the collar, and pull the entire leg and transom shield off the engine (suggestion, do NOT do it alone...on the hill where you unloaded the engine from the truck).
It has a fairly heavy oil leak from the flywheel cover, so I currently am working on getting at the seal to replace it. I've also read that the PDS bearing should pretty much be replaced any time you're in the neighbourhood.....but I have a couple questions:
1) How much should an open 6206 bearing cost? I find them running anywhere from $6 - $200 each, and that seems a pretty major extreme to me, and I can't believe they should be replaced any time you're in the neighbourhood at $200 a hit.
2) Now that I have the flywheel cover off, where do I go to get at the seal? Obviously I have to remove the flywheel, and am not sure how to best go about that, which leads to...
3) Who makes the best manual? I've seen recommendations of a couple different brands, but I don't want to have to shell out a ton of money for a manual more than once. The more information the better, even if it costs a few bucks more. I'd love to basically find an 'Idiot's Guide To' my engine.
4) Are the rubber boots for the outdrive different from any one supplier, or can I just buy whatever's cheap on eBay? Is this a standard part that fits something like 9000 different models, and won't be going away anytime soon, or should I buy a couple sets...just in case?
5) This is an extremely new endeavor to me in completely uncharted territory. I'm decently handy, I'm an electrician, but have only done small engine work (scooters). I have a friend who has worked on quite a number of small vehicle engines, but he's basically a weekend trip away. Is a lot of this something I can handle with a manual and patience, or am I in way over my head?
Thank you SO much for reading all the way to the bottom of this post. I keep Googling for answers to my questions, and I keep seeing a ton of useful looking info at iboats, but it appears their website is down or something. I haven't been having nearly as much luck searching on here, so maybe someone can help point me to a number of "read this first" threads.
https://www.dropbox.com/s/xrfrdbwpaqzkrce/20140827_202537.jpg?dl=0
https://www.dropbox.com/s/c5xmx7fdvl7s8z8/20140915_182446.jpg?dl=0
https://www.dropbox.com/s/tyd1umkjv1sof6b/20140915_182458.jpg?dl=0
https://www.dropbox.com/s/2ug5hjveac7gfex/20140915_185339.jpg?dl=0
https://www.dropbox.com/s/h63fgsq84pq2he3/20140915_185348.jpg?dl=0
Thanks!
Alton
Ps. In case anyone is wondering, the wooden triangles leaning against the boat are going to become its "winter shelter" so I can work on it in the rain and what not. And yes, I have a cover for the boat, but I have it off to air out the boat.
Thanks!
Alton
