Guys, it's the AQ130 which is the pushrod engine. It doesn't have a timing belt.
The indexing is about position of the distributor once it's installed. Theoretically, the distributor can be in any position as long as you put the plug wires in the right place. From a practical viewpoint, there is limited room to rotate the distributor because of the position of the condensor. Once you line up the rotor to point #1 to TDC, you still need to have enough room to rotate it for timing. You also need to make sure the gear and shaft assembly first fits properly into the oil pump and then into the cam gears.
It's mostly trial and error. Once the engine is at TDC, do a test fit. You can rotate the oil pump from above with a long screwdriver to get the tab on the shaft to slide in. It can fit properly one of two ways. Look at the slots on the gear. These fit with the tabs on the bottom of the distributor but are NOT centered with the shaft. You'll need to look at the distributor to align the tabs on the bottom with the slots in the gear. See where it fits best so that the condenser is on the right.
You may need to lift the oil pump/dist gear assembly and move it one way or the other. If you do, you'll also need to move the oil pump slot just a little as well.
Take your time. You'll most likely need to do this a few times to get it right. Do NOT tighten down the distributor until the tabs and slots are aligned correctly. Can get to be an expensive mistake and you'll get to learn a whole new lesson about distributors that are compatible with this engine, and how much they cost!
