Leif Pickwell
hi all, new boat has a volvo aq130 in her,has been sitting for a year) took it for its first run on the water 2 weeks ago would die out under load and not get on to plane, replaced points,condenser,plugs, leads, took it for a run got her up and going on the plane for about 10 seconds then she died, got it started again and after a short idle it got up on plane again then stopped again. could this be the coil or would it be more likley fuel? I wound it over with fuel pump outlet off and it was pumping fuel not sure how much it should be pumping
