AQ130 270 CORRECT PROP SIZE
hanius
"i have a 1975 glastron v-179.
"i have a 1975 glastron v-179.. with a volvo penta aq130c and a 270 drive 9;5;1 ratio does anyone know the correct prop size and were i might find one at ALSO does anyone know the right ign. timeing??? [email protected]
Thanks"
"I suspect you mean a 2.15:1 r
"I suspect you mean a 2.15:1 ratio. You will have to try several propellers and see which one gives you the best hole shot and allows you to reach the maximum engine RPM. I would start testing with a 14 x 17 and take it from there. You may end needing a 14 x 17, a 14 x 19 or a 14 x 15, but you won't know for sure which one works best for you until you do some sea trials."
I just bought a 74 Glastron CV
I just bought a 74 Glastron CV16ss with the AQ130c and 270 out drive. It has a 15 x 19 prop on it. Previous owner used this prop without any complaints. I havnt had the boat in the water yet.
"THANKS ALOT ... ILL GO BUY ON
"THANKS ALOT ... ILL GO BUY ONE TODAY, IF YOU EVER NEED ANY MORE HELP WITH THE AQ130 HOLLER AT ME"
