Hello.
Last year I got myself a new/old boat with an AQ130 engine and 250 stern.
The boat itself is a NORCEM 21 (DC?)
Had a broken camshaft and a clogged cooling.
Took it apart, cleaned, inserted new camshaft, new sparkplugs, new impeller. It has an electronic ignition built in, checked the timing, its ok.
The compression was also ok for an old engine (175 PSI).
Also cleaned the carbs (2 Zenith-Stromberg)
Now I have a few questions, problems.
1. At WOT the revs go only up to 4000-4100 (manual says cruising speed is 4600'ish)
2. Speed according to GPS is 25 mph max
Otherwise the engine is starting like a charm, cold or warm, doesnt stutter or anything.
The prop has some wear, but i dont know what ratio prop it is. The seller said its the original for this stern/engine, but i dont know.
Also it has an oil leak near the flywheel, i guess a faulty seal at crankshaft?
Engine temp at top of the engine was about 100 C. Block was about 90 C. Is that too high? (laserthermometer)
Anyways, I think it is a good old engine, now I just need some advice on how to make it purr a bit better.
Thank you.
Thank you.
