Aq125b
volvoled
"when checking motor in my yar
"when checking motor in my yard, i have the prop down and everthing is fine, but when I raise the prop, The water comes out the exaust and around the boot.is this a problem? also what would be a good replacemetn engine for 86 bayliner ciera sunbridge aq125b"
"Hi,
The exhaust bellows ha
"Hi,
The exhaust bellows has a hole at the bottom so that any remaining water left in the outdrive and exhaust can drain when the outdrive is tilted. This is the way it is designed to work.
Regarding replacement engine, you are pretty much limited to a Volvo engine (OHC or OHV) if you intend to keep your current outdrive and bellhousing (Fords or Chevs won't fit). If you are considering an increase in HP, you may want to consider a dual carb arrangement (AQ145, AQ151 or AQ171). You can download the brochures from here:
http://www.volvo.com/volvopenta/na/en-us/marineengines/outofproductionengines/ga sengine/sterndrive/
Is there something wrong with your current engine?"
"Thanks, I just wanted to know
"Thanks, I just wanted to know what my options are on engine and/or outdrive replacement"
