"I was having a few issues wit
"I was having a few issues with one of my AQ125B's so I replaced my plug wires distributor cap and rotor. I changed out the points with the Hot Spark electronic ignition conversion. I cranked her over and she started fine. I checked the timing and it was at 15 degrees advance at idle. The manual says 6 degrees so i adjust it to that mark. Does not idle so well here. I throttle up to 35oo rpm and check the timing again and it is at about 25 degrees instead of the reccommended 30-32. Which is more important? The high rpm or the idle?
Also when I throttle up I have to pump the throttle to get up to speed or it stalls out, what could be the problem here, it runs fine at cruising, but it is a bit of trouble getting there."
