"I seem to be running into a l
"I seem to be running into a lot of problems this summer. The other day at the lake my engine cut out, I tracked it down to no spark...
I removed the coil lead to the dist and turned ignition on, then I manually rotated engine and I got a spark as I would expect. I think this eliminates the coil and the coil wiring.
Removing the spark plug wires I couldn't seem to get a spark at all. I removed the dist cap and then put it back on, a few minutes later it fired up and went no problem. Next day I couldn't start it again.
This has the hot spark ignition. I am wondering how this system works... I believe that as long as it is allowing the coil to discharge at the right times when the engine is being rotated then it is working and doing its job and is probably not the culprit... From this diagnoses does it sound like it is the rotor or cap? Further, could the rotor or cap really cause it to cut out so suddenly and not start again. It is either running perfect now or not even trying to fire...
Lastly, will an automotive cap and rotor fit?
Thanks a lot, this site is great!
Jamie"
Jamie"
