I am thinking of tackling engine removal for the purpose of changing out the rear crank seal in my '83 Bayliner 1950 Capri. I have a Clymer shop manual that covers Volvo-Penta stern drives from 1968 to 1993. What I was wondering, can the engine be separated at the bellhousing/engine block connection or do I have to pretty much do it as described in the Clymer manual. Which is removing the upper gear housing to get at the thru bolts that connect the engine to the outdrive unit through the transom? Also, is the rear seal changeout fairly easy? Thanks for all help. Marc.
