discobayken
"1983 19 ft glassply hardtop.
"1983 19 ft glassply hardtop. She has a low hr aq125a / 270 outdrive.
I have recently done (or am doing) the following:
1. replace timing belt and tensioner
2. install pertronix, flame thrower, new cap, rotor, wires, plugs
3. flush heat exchanger, new antifreeze, replace cap, install new impeller
4. install new starter (old one was rusty and dragging and clicking).
5. service outdrive.
6. run some seafoam through carb & clean arrestor/ replace fuel filter
7. Inspect / clean and replace electrical terminals as necessary
8. oil & filter change
9. Replace exhaust manifold.
What am I missing here? I'd like to make this boat as dependable as possible w/o replacing EVERYTHING at random.
Should I install a new fuel pump for the hell of it? Alternator works fine but looks like its original. Leave it? replace it? rebuild it?
morse shifter a little stiff going into rev. into fwd is fine.... is it possible to lube it? adjust it? or does it need replacing?
Any and all other advice is appreciated. What else should I do to her? Thanks!"
