newbieornottobe
"Greetings.
Just got a 1985
"Greetings.
Just got a 1985 Bayliner Capri bowrider (17 footish) for almost nothing as it needs a new interior. The original owner had it pulled all out for a re-do. I'll be putting in a floor, carpet and seats, and doing any needed engine maintenance to get it back to good running shape. (it does run)
It has an AQ125 (not sure if A or B?), and the 270 outdrive.
I'll need a new prop...can't tell if this is a short or long type though? And is it a problem to run the reverse pitch prop? Read it's no problem, and I can get a good deal on one. (assuming the shaft is fine)...one blade has about 1/8 inch of one tip rather stripped away...as if it hit a rock.. could be from our infamous one in the launch area here. Or could have been from just being moved while on land.
I'll be replacing the drive bellows (have that). I'll be installing a new impeller (coming tomorrow)
The guy I bought it from said it has a cracked water tube, and it sure does.
I hope that's the limit of cracked anything. Can't tell yet though. What I worry about is why this one cracked...looks like a winterizing issue...water remained inside?
How much are these water tubes? Can a new section be spliced in..using oversized outer pipes soldered to connect say one inch beyond the join each way? Can I just close it up a bit , then solder or braze?
This looks a bit like a snake which ate a rat! Thus wonder if soldering and using the original would cause some kind of Bernoulli principle as to the flow slowing then speeding up again. Is there a way to make your own? Bending I can do, creating the flanges would be an issue though.
If the pipe is $25, that's nothing, but if it's $100, that's not nothing.
It's a dealer item according to the VPStore.
Thanks for any advice. Attached a pic.
Robert
Just got a 1985
"Greetings.
Robert
